advice on injectors and fuel system for E85
looking to take the plunge and go E85 on my TTiX forged LS6
looking to make around 900 hp
a couple different injectors I've looked at
127 bosch
160 bosch white top
the 160s I've found for just over 500 new and should be MORE than enough
I'll be running a Haltech computer and running two tunes
1 pump gas with meth injection
1 E85 for kill setting at 900 hp
looking at the ECS stage II fuel system
any recommendations? the Haltech has a flex fuel sensor and I'm thinking I need some additional sensors for the fuel pressure for the pump gas and also the alchy pump
also looking at doing the EGT sensors on each cyl to help with individual cyl tuning and implementing the fail safes
like to get any recommendations you all have
thanks!
127 bosch
160 bosch white top
thanks!
it's a 2003 C5 Z06
lonnie for sure has a nice double pumper setup. not sure I can get big enough pumps in there for 900 at the tire on E85 but it's certainly an option
any feedback on the bosch 160 white tops
how hard are they to get to idle? good injector info and linear for tuning?
I can get a set for 560 new, anywhere cheaper?
thanks!
thanks!
