compressor, turbine match
Old 11-01-2013, 12:45 PM
slaw's Avatar
Default compressor, turbine match
I was wondering if anyone has used the GTX3576R turbos in a twin setup on a LS7. This is a street car only for now. I'm curious about the turbine match. An ar of .63 or .82 for the street. I know there are other factors to consider, gear ratios and such. If someone has had good results with these could you let me know. thanks in advance.
Old 11-01-2013, 02:04 PM
stevieturbo's Avatar
I know a guy here in the UK put a pair of normal GT35's on his 7.0 RX-7, think he said his were in the 1.0A/R range though.
It is making good boost by around 3500rpm
As they typically use the smaller T3 flange, a higher numerical turbine ratio probably makes more sense, especially with the bigger motor.
Old 11-01-2013, 02:30 PM
slaw's Avatar
thanks stevieturbo. i will look into the bigger a/r as well.
Old 11-01-2013, 02:31 PM
Toxic-Evo's Avatar
with that small of exhaust weel you want/need ATLEAST a 1.0+
Old 11-01-2013, 02:32 PM
Toxic-Evo's Avatar
or get a Small t4 housing.
Old 11-01-2013, 02:48 PM
Dont think Garrett offer the 35 with a T4...and either way, turbine wheel is still the same size.
Old 11-01-2013, 02:57 PM
slaw's Avatar
i was thinking of the Tial stainless turbine housings. they come in a .63, .82, and a 1.03 for that compressor. But those are a V band housing. Have you heard of anyone using those?? i think that's correct, i didn't see a 35 with a T4 only T3's and Vband.
Old 11-01-2013, 02:59 PM
They're based on T3 sizes anyway, so are more for neatness and ease of fitment compared to a 4 bolt
Old 11-01-2013, 09:44 PM
slaw's Avatar
stevieturbo i watched the vid. nice run. i have friends in liverpool and manchester. worked with them in iraq. i like the history over there but not so much the weather LOL. thanks for the help.
Old 11-03-2013, 07:59 PM
Toxic-Evo's Avatar
...... so get with a company that offers what you need... not with a name.
PTE for the win.
Quick Reply: compressor, turbine match
