Any 55-57 turbo LS builds
Looking for some info on turbo set up and position, twins or single. Also what oil pan to clear stock front steering on a lowered 55. Thanks in advance. Scott
you'll need the Holley pan to clear everything.
I used a stock truck pan but had to cut it in order to fit.
As for a turbo.....I am looking at going twin on my 57' and I'd like to use internal gates to keep everything in a tight package.
Here is my build. It's a 6liter with twin 76mm turbos. Turbo 400 Megasquirt fuel management.
https://ls1tech.com/forums/forced-in...-ls-build.html
I have a GM hot rod pan that I am going to mock in and see if it clears. Thanks for the info.
