My 69 Nova L33 S476 project (Finally Some Runs)
#62
What did you use to mount it? I was always told that the taller small block stands would have to be used and that I would have to remove my big block stands and mounts.
You used the big block short stands and the big block mounts? Thats the first I've heard of this being done. Does this put the engine in the same location as normal 1" setback mounts would, leaving the bellhousing in the stock location?
#64
All that said, I now can't get the pass side exh manifold on. It hits the frame. I am now going to have to get creative.
I highly doubt this would even have a chance with headers.
#66
I used hooker 12611 mount plates. The stock interlocking mounts that were on my big block and the big block frame stands. I left the trans in the car, so it is in the stock location.
I always wanted to use the big block stands to mount the engine lower for better center of gravity, while keeping the engine as far to the rear as possible for best front/rear weight distribution. If I can use my old big block mounts/stands that are laying around and keep the trans in the stock location while dropping the engine down and gaining firewall clearance, this is a complete win/win for me.
#67
I'm just kind of confused at how the passenger side head has a full inch of clearance, yet the trans is in the stock location. Normally when using setback mounts to keep the trans in the stock location, the head is so close to the firewall that you can't get a finger behind it.
I built it as a TH400 BB car.
That is all I know.
Also, I just measured it to be 3/4"
Ron
#68
Was just looking at it. It doesn't have a good outlet angle, but it also doesn't drop down near as far as the LS4 manifold. I may begin molesting it tomorrow.
Would like to see your photo.
Ron
#69
My car was also a TH400 big block car. I'm just trying to decide which route is best at the moment, especially since I have both the big block and small block stands and mounts, along with 1" setback plates (car shop, not holley). Maybe someone else can chime in about why the placement with the big block stuff is different. Maybe it has something to do with oil pan clearance? Thats the reason they suggest going with the small block stands, because the pan will hit the subframe.
Sorry if I'm bombarding you with questions, but this has just brought my swap to a halt.
#71
The holley plates you're using are actually 1" setback mounts. I'm just a little confused is all. Most people who use setback mounts have clearance issues.
I'm using the Mast pan. With this setup, it clears the subframe by 1/2".
The factory BB frame stands move the engine to the pass side for steering box clearance. Mine are GM stands.
The LS literally fell into place.
So what photos can I get for you to help?
Are you doing a turbo deal like me?
Be glad to help if I can.
I've not read of anyone trying this either. I had the parts, so I tried it.
Ron
#72
Here we go, Nate (LS1Nova) answered the question about the LS4 manifold bac in dec of last year.
https://ls1tech.com/forums/forced-induction/1608059-68-camaro-5-3-single-turbo-swap-what-manifolds.html
Now why didn't I read that?
The casting number on my truck drive side manifold is 12602040
#74
Alright, I helped you in a completely negative way.
Ron
Ron
On another note, where did you get the Mast pan for $399?
#78
Their pickup yes. Rather frustrating. I suppose I should have called them, but I didn't want to stall my project while they figured it out. With the room I have from the steering linkage to the pan, I might have been able to use an F-body pan. Too late now.
Here is a couple of exh fitment photos. Thanks mike, I see what to do now on pass side.
Also note how close the drive side is to the steering box.
Ron
Ron
#79
looking good.
my left side is about a 1/4 inch from the steering box as well. the pass side is a little work if you aim just under the lower radiator hose you shouldn't have any issue and keep an eye on where you put that v band if it lines up with the control arm bolt it is better shorter or longer to clear that bolt.
#80
Thanks.
I cut on the manifold today and tried to fab up a mating pipe. I'm of the eyeball then cut school, so at this point I had to walk away and try again tomorrow. Before I ruin the manifold.
Thanks for the tips.
I'd like to find some thicker wall 2.5" tubing as well.
