Fuel Sytem Question
Fuel Sytem Question
FYI, I have searched the forums but have not found my answer.
I have a E30 M3 with a lightly modded Ls1. I have added a turbo (7868)and I am about to begin modding the fuel system but I have a couple questions. Right now my my fuel system consists of..I shooting for 600 rwhp MAX.
Aeromotive 340 Stealth Pump
Corvette Fuel Filter/Fuel pressure Regulator Combo w/Return Line
-6 Stainless Lines
Stock Fuel Rail.
40lb Injectors
I plan on upgrading to
Aeromotive Boost Reference AFPR
60lb Injectors
My questions are:
Do I remove the Corvette/Fuel Filter/Pressure Reg? (Im thinking yes being that it regulates the pressure to only 58psi ish) If so I plan on just replacing it with a in line fuel filter.
If I remove the Corvette Filter/Regulator, does the AFPR control the fuel return?
I want to use the stock fuel rails.
Any information would be HIGHLY appreciated. Thanks
-6 Stainless Lines
Stock Fuel Rail.
40lb Injectors
60lb Injectors
My questions are:
