THE LIST-Top 10 STOCK BOTTOM END LSx(s)
#82
So my high numbers on the speed density tune ended up being 839hp 847rwtq @ 15.77lbs of boost with some bad bad wheelspin on the dyno (puny 245 tires on stock 16s) which caused a dip in the graph. My tuner said he had troubles keeping it from spinning on the dyno.
#84
and is your tuner attributing these gains to just removing the MAF?
#85
Please post a dyno slip or video, and people will want proof since you are now the highest HP stock bottom end blower car. Good work. How much boost out of that Ysi?
#86
Yea still on the 20g's. The gains arent all from removing the maf I'm sure but could be in part. Stock maf has to be pegged at these levels I have to believe. I had him do a speed density tune on the car so I'm sure with that being more involved than a standard maf tune he tweaked things here and there. Maybe more aggressive timing since I'm on E85, not sure on the details yet. I wont pretend to know all of what was done tune-wise, i get lost with a lot of that. I'll ask more specifics when i take delivery of the car. There were some imperfections from the paint shop so he's having them redo the hood.
#87
126k LS1 stock short block
Huron Speed kit
Turbonetics 7875 .96 a/r
317 heads
1218 pac springs
Pro comp head studs
LS9 head gaskets
Stock cam
Brain Tooley lifters
7.375 PR's
60lb Siemens
Racetronix fuel setup
91 octane
Full 3" exhaust to a Hooker Maxflow muffler
Made 638/623 SAE.
Huron Speed kit
317 heads
1218 pac springs
Pro comp head studs
LS9 head gaskets
Stock cam
7.375 PR's
60lb Siemens
91 octane
Made 638/623 SAE.
#88
Huron Speed kit
317 heads
1218 pac springs
Pro comp head studs
LS9 head gaskets
Stock cam
7.375 PR's
60lb Siemens
91 octane
Made 638/623 SAE.
http://youtu.be/xj58eeIUqG4
Huron Speed kit
317 heads
1218 pac springs
Pro comp head studs
LS9 head gaskets
Stock cam
7.375 PR's
60lb Siemens
91 octane
Made 638/623 SAE.
#92
Regardless of what it makes i really want to get into the 9's this year with the stock bottom end and 6spd. Car is 3600lb's so itll be tough
#93
and i was rather liking the #1 spot
cant wait to see what you can muster out of the stock 5.7. Its crazy what can be done with these things these days. My tuner said that my car was actually his 2nd highest hp STOCK ls engine he's put out. I cant for the life of me remember what his highest was.
#94
According to this list its 839hp, but i recently saw that someone at RPM made 847ish(?) on an ls6 with a YSI. That is the absolute highest i have ever seen out of a stock bottom ls1/ls6. My goal has always been to push this to 850 but i may have to do 860 now lol. Im really not worried about the motor since these are only dyno pulls, I'm just not sure ill be able to squeeze enough boost out of this turbo to hit it.
#97
Its seriously looking like these are getting stronger with age. I know tuning has come a long way and better turbine technology is really starting to take off with the OEM's going boosted, but you just didnt see this many stock motor cars making so much power years ago.
Im not sure if its his car or not. I saw it on RPM's facebook, not tech. I'm not even sure it was RPM at this point, all I know it was at as reasonably well known shop. If he chimes back in and says he turned it up, i wouldnt be surpised.
