Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
Old 06-10-2014, 10:30 PM
  #81
RonSSNova's Avatar
Nice work by you and your shop!
I want your job.
Got a turbo on the lawn mower yet?
Ron
Old 06-14-2014, 06:03 PM
  #82
transbird95's Avatar
Just read the whole thread. Amazing work and thank you for still supporting the LT1.
Old 06-14-2014, 08:35 PM
  #83
Sales@Tick's Avatar
I want your job.
Ron
We've talked about putting one on our ATV we use at the track! LOL
No problem! Working with the 24x system makes a LT1 fun to work with and really opens up the possibilities for a build like this.
Old 10-06-2014, 02:24 PM
  #84
mrstepheneades's Avatar
How about 907/865 lol. Nice numbers Randy. This was at Tick last Saturday for the dyno challenge.
Old 10-06-2014, 04:06 PM
  #85
n2oblkz's Avatar
VERY nice!!! Good job.
Old 10-06-2014, 04:26 PM
  #86
Sales@Tick's Avatar
Gave it a few degrees of timing, I think she liked it...
Poor thing runs out of steam quick, but she pulls hard to 6500!
Old 10-07-2014, 07:36 AM
  #87
Makes the power down low for sure.
Old 10-09-2014, 08:42 AM
  #88
Sales@Tick's Avatar
No love for the LT1 Juan?
Old 10-09-2014, 03:48 PM
  #89
scottywheels's Avatar
Sick... MArtin I also emailed you at the shop . scottiewheels123@gmail.com
Old 03-12-2015, 01:33 PM
  #90
lcvette's Avatar
Awesome build guys! I ran into oil pressure fall off issues over 800rwhp, however my build was a LT4 vette and it used the oil filter adapter that I believe/hope was a part of the problem. Log your oil pressure. Mine would peak around 80psi and fall off to 40psi. This caused some bearing problems obviously. New twin build I deleted the oil filter adapter and fabricated everything to clear an HP4 Fram/wix racing filter. Haven't gotten it finished up to test yet. The cylinders were still perfect on tear down at 939rwhp. Main destruction was crank thrust (manual car) and some heat fractures in the crank and spun bearings. Pretty much same build with a few minor brand differences, eagle, Callie's caps, Ross custom pistons, 9.5:1.
How this helps and would be interested/releived to hear you aren't seeing the oil pressure drop reinforcing my suspicion of the vette filter adapter being a restriction on those fast rpm ramp ups during spool.
Chris
Old 06-16-2015, 08:34 PM
  #91
Prototype007's Avatar
Just now seeing this thread for the first time.
This build looks like some high dollar magazine machine. Great work and numbers to say the least!
Old 06-19-2015, 09:57 AM
  #92
Sales@Tick's Avatar
Thanks!
Old 06-19-2015, 11:19 PM
  #93
SpeedJunkee's Avatar
Man! If that car made that with those parts, I am very excited to see what mine does with a better setup!
Probably a solid month, maybe 2 before I have numbers, but I have a bit of more higher end parts than on this build.
None the less, awesome to see another wicked LT1 out there. Great job Tick!
Old 06-20-2015, 01:11 AM
  #94
brettmc's Avatar
Great job by the owner and Tick. I can imagine the surprised, hurt looks that one will get on the street.
I have an LT1 turbo being built at a local shop here. I hope it pulls as hard as this one.
Old 02-05-2016, 12:03 PM
  #95
SwampWS6's Avatar
Martin, Randy
Hows the car doing so far? Any updates? Anymore dyno pulls, track appearances? Love this car! Just wanting to see where its at right now......
Old 02-05-2016, 12:18 PM
  #96
Sales@Tick's Avatar
This car was never intended to be a track car so much as a nasty street beast. The engine is out at the moment due to a broken lifter. I will be putting it back in here in a couple of weeks.
Old 02-05-2016, 12:46 PM
  #97
SwampWS6's Avatar
Man, I hate to hear that. Thanks for the update though. LT1FTW!!!!!
Old 02-06-2016, 07:37 PM
  #98
oldschool's Avatar
Great build...please keep us up to date. Refreshing to see something different!
Old 03-03-2016, 10:34 PM
  #99
lt4388stroker's Avatar
Originally Posted by SwampWS6
Martin, Randy
getting ready to put the motor back in, ended up spinning a bearing, had to get a new crank, 2 rods, 1 piston, set of lifters, 2 or 3 intake and exhaust valves and little machine work on the heads.
Switching my water pump style from remote mounted down by radiator to back in waterpump casing should help keep it much cooler. Also putting a different cam in it.
We are geting it ready for the Virginia 1/2 mile shootout April 30th/March 1st
Old 03-04-2016, 07:28 AM
  #100
SwampWS6's Avatar
Sorry to hear all the bad news . That is a lot of problems but I am glad you are getting it back together. Is Martin specing out a new cam for you? PM me the specs if you dont mind, I hope this car hits 1khp. That would be great. Also, do not forgot to post some videos of the car at the event!
Even my wife knows about this car because I talk about it so much! Good luck!
Quick Reply: Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
