8-Rib or 10-Rib for F1R
Switching to forced induction. Im currently collecting parts and Im trying to figure out if I will be ok with an 8-rib setup or if I need to go with a 10-rib setup.
I would really like to make above 900hp if that makes any difference.
Definitely go 10 rib with an F1R if at all possible... I've had pretty decent luck with a 10 rib.... I've seen lots of people with issues with an 8 rib on an F1R.... Having the blower on its own belt will help tons also... Get the best blower bracket you can get.
You should make 900+ with this setup.
Just try to keep the blower inlet as clear as possible.. F1Rs don't like ANYTHING in front of them...
IMO get a ati balancer w a 10rib pulley attachment pulley. Or
U can use same ati crank pulley and use a LSA camaro/ctsv attachment pulley from jre or lingenfelter. Although they are 8 rib blower pullies.
Another option is using a jegs sc crank pulley. Has the blower/acc /ac drives built in and comes in overdrive ratios for the blower drive section. Pretty cheap too. About 400 or less. They look like the stock zl1 ctsv gm crank pulleys but in all the offsets. Fbod/vette/truck.
Etc. Jegs is 8rib pulley iirc
On my PD blower project. I'm using a CAT crank pulley w a lingenfelter sc crank pulley for a LSA . making all my own drive. Its 8rib but fine for what I'm building.
Its all parts i put together on my own. But if you need help figuring it out. Hmu.
I can help give u some ideas.
