Can we get our stock bottom end 5.3 in the 4's???
Old 02-17-2014, 08:44 PM
Sbryson02's Avatar
Originally Posted by nmass399
Will be rootin for it to happen, getting alot of fame for this either way.
Have you guys took a peek at the bottom end to see if the rods look ok?
No, we've mentioned it a time or two, but then we decided ignorance is bliss.
Old 02-17-2014, 08:48 PM
Sbryson02's Avatar
Originally Posted by mrstepheneades
That's exactly how I want my turbo sitting and the downpipes too. Man that's awesome.
Thanks! We're very pleased with how it turned out.
Originally Posted by rkreigh
you guys should be like a funny car team and have spare short blocks
wouldn't be all that expensive, and as long as you can thrash a new motor in who cares if it blows up
good luck!
The only downside to that is we're pretty lazy. lol
Originally Posted by slowlsx
I think it will do it easy as long as the engine holds. From pt88 to a gt55 is a big jump in power, im sure he has that pt88 maxed out as well.
I feel like we got everything out of the PT88 that we could. We're just hoping the engine has a few more passes in her,
Originally Posted by navyblueSS
Goodluck, hope it makes it!
Thanks!
Old 02-17-2014, 09:39 PM
LS1Tech Sponsor
hellbents10's Avatar
Car looks great with the forward facing turbo too!
Forcefed86's Avatar
In for results, good luck!
Old 02-17-2014, 09:43 PM
a.white86's Avatar
I'll look for y'all at Valdosta Friday and stop and say hello.
Old 02-17-2014, 10:27 PM
KnightmareLS1's Avatar
Subbed for results
Old 02-17-2014, 11:18 PM
8 Second Truck Club
Blown06's Avatar
Car is absolutely perfect.
Old 02-17-2014, 11:22 PM
tonypaul's Avatar
If you were rolling out 5.09's before with the old setup, I see no reason why you couldnt pull into the 4.90's with the improvments that have been done. With the right tune/setup/air I bet you can do it, but the question is how many times you can do it before the motor gives....
Old 02-17-2014, 11:40 PM
00MaroonZ28's Avatar
x2
Old 02-18-2014, 04:39 AM
95bowtie's Avatar
Wow 30psi out of the pt88...how do you keep the heads down with the 4 bolt heads?
Does the meth help with that or was it just luck haha
Old 02-18-2014, 07:36 AM
LS1Tech Sponsor
RPM and a good tune up will helps with the head issue I am sure.
Old 02-18-2014, 07:43 AM
  #32
Sbryson02's Avatar
Thanks guys! Yeah, I do think the methanol helps. Less chance of detonation. Like Hellbents10 said, good tune up and we only spin it @7000 rpm. I contribute most of our success to dumb luck. When you meet us you'll see what I mean. Lol
Old 02-18-2014, 08:44 AM
  #33
3stgstocker's Avatar
Good luck man I'm gonna try n make it 2 valdosta
Old 02-18-2014, 01:27 PM
  #34
kjm
kjm's Avatar
What does the car weigh without driver?
What gear?
What height tire?
Awesome work. You guys have to be doing something right.
Old 02-18-2014, 01:41 PM
  #35
LinearX's Avatar
What gear?
What height tire?
We haven't weighed it without the driver. It is 2965 with him in it.
3.55 gear
275/60/15 MT Pro Radial
Old 02-18-2014, 02:12 PM
  #36
Photochop's Avatar
Maybe I missed it, but what rpm are you turning the motor to? Ported stock heads, pretty aggressive cam profile?
I'd agree it's a stock bottom end. I can't count how many guys went from heads/cam ls1s (and still do) that change out the rod bolts when they do a cam swap that makes power past 6300 and they still were/are considered stock bottom ends.
Old 02-18-2014, 02:27 PM
  #37
mrstepheneades's Avatar
He said 7000.
Old 02-18-2014, 02:47 PM
  #38
Sbryson02's Avatar
We turn it about 7k. The cam isn't super aggressive, it was actually ground for a nitrous 5.3, we just had it on the shelf, so we used it. I'll get the specs.
Old 02-18-2014, 03:03 PM
  #39
Sbryson02's Avatar
226/234 .598/.601
Old 02-18-2014, 03:32 PM
  #40
RonSSNova's Avatar
We will want to see the videos!
Very cool setup
Ron
Quick Reply: Can we get our stock bottom end 5.3 in the 4's???
