Aes 390 / F1A results?
#43
Did you every figure out the cause of the trouble, boost leak/pulley issue or whatever? Trying to see what these AES 390/F1A combos are putting down. If something ever happens to my motor I'll be looking for one : )
#44
Sorry for delay. Checked for leaks and nothing, I went to the bigger 8.65 pulley and also went to 127 injectors. So far while tuning in only seeing 10.5 psi at 4700 rpms with no filter. I saw about 15 psi at around 6800 rpms; just I balling it didnt have hp tuners connected. Still no satisfied with results
#45
8 Second Truck Club
I actually don't think it's too far off. Your **** weighs 4000 lbs.
To give you an idea of what 4000 lbs does for your et/mph
My truck is a hair over 4000lb (4100), I run a solid roller 408 with an f2. At 15lbs it has trapped around 145. A far cry from a run of the mill aes390/f1a serpentine set up.
#46
This sounds like what I'm going through. My best pass MPH was 130.9 with a 1.66 60ft. Boost peaked at 13lbs with a 4.13" blower pulley and 8" crank pulley. Needless to say i was very disappointed. This was through a 4l80e and 9" with 3.50 gears on drag radials (<<<as it sits in pic). I had to give it around 65% throttle or so out the hole or it would just spin. I recently swap gears to 3.70s and had my torque converter re-stalled to 4000 rpms from 3200ish. When I shifted at 6600 my revs dropped 1700 rpms. Now it suppose to drop down only 1000-1200 rpms keeping me in the sweet spot (I think). We'll see what's what when I get back to the track.
#47
I actually don't think it's too far off. Yur **** weighs 4000 lbs.
To give you an example of what 4000 lbs does for your et/mph
#49
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#52
LS1Tech Sponsor
Andy, what is your fuel pressure at 6500 rpm? 15 psi at 6500 rpm, what is your impeller speed at? Bob
__________________
#54
LS1Tech Sponsor
I asked about fuel pressure as I didn't think you were spinning it as hard as you are, and you're at 80% duty cycle. I thought perhaps your fuel pressure is down, but with your impeller speed where it is at, your duty cycle is just fine. Bob
__________________
#56
LS1Tech Sponsor
That's it!!!!!!!!!! I didn't know you were so far up there! If you get your car down to a track where it's below 1000 ft, you're going to see a huge difference in mph, and you'll make a lot more boost! Bob
__________________
#57
LS1Tech Sponsor
Andy, I just e-mailed you all of your receipts since I had them up on my computer. Bob
__________________
#60
LS1Tech Sponsor
Andy, have you seen my thread on the new F-1A? https://ls1tech.com/forums/forced-in...-9-volute.html If you sent in your blower to have it converted to the new F-1A, you would see a lot more boost and power out of it. One guy reportedly bolted on the new F1A in place of his old F1C and picked up way over 100 rwhp. At some point you're going to start pushing water with your four bolt block/head combination, and if I were you I'd go with the upgrades for your F-1A. Please call me for pricing. Thanks. Bob
__________________
