procharger pulley belts??
Old 04-18-2014, 11:30 PM
210guy's Avatar
Default procharger pulley belts??
So I was wrestling with the procharger trying to bolt it up to the j bracket and realized my belt was too small and not letting the holes line up. So it being Friday I won't be able to get the belt from brutespeed till next week and I need it now
Can I find these belts at a local auto store or am I SOL?
Thanks for the help in advance
Old 04-19-2014, 12:27 AM
AbsolvedJD's Avatar
You might be able to get them locally. They aren't Procharger brand belts or anything special like that. Call around and you might get lucky.
Old 04-19-2014, 01:30 AM
210guy's Avatar
Red face
Ok ill call around tomorrow. Thanks man
Old 04-19-2014, 05:33 AM
stmz28's Avatar
I get mine from napa
Old 04-19-2014, 06:22 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
These belts stretch a lot during the first hour of usage. Bolt the blower on without the belt being on the crank pulley, then get the belt as far on to the crank pulley as you can and rotate the engine to get the belt to "pop" on. After approx an hr of usage you'll find you have to adjust the belt tension. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 04-19-2014, 06:50 AM
forcd ind's Avatar
not much help w/o knowing what kind of belt, cog, 6, 8, 10, 12 rib serp., etc
on a 12 rib I have used 2-6 rib
NAPA and others do have some diff sizes and rib's
if its the right belt, like Bob said, it might stretch a little
I have bolted up everything, left the drive pulley off, then put it on with the belt-all depends on the setup
Old 04-19-2014, 02:57 PM
210guy's Avatar
Ya went to Napa but they didn't have it ended up going to a local auto store and getting it through them
Old 04-19-2014, 03:00 PM
210guy's Avatar
Bob I'm running the 7.65 crank pulley and the 4.50 head unit pulley so what part # belt would I need?
Thanks
Old 04-20-2014, 10:16 PM
tranb000's Avatar
K080415 I have the same pulleys on mine just put a green stripe gates on this week what boost should you make with those pulleys
Old 04-20-2014, 10:52 PM
AbsolvedJD's Avatar
tranb000 is correct, according to this link on Bob's website (assuming you have a 98-02 fbody with the Procharger 8 rib bracket).
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
Old 04-21-2014, 07:51 PM
LS1Tech Sponsor
Yes, that would need a 41.50" long belt if using the ProCharger J Bracket. Bob
__________________
Old 04-21-2014, 09:30 PM
vwdave's Avatar
The procharged F150 Ive worked on had a belt so damn tight the only way I could get it on was by getting it started and bumping the starter. Tight as a guitar string. According to procharger, this is perfectly normal.
Old 04-22-2014, 12:00 AM
210guy's Avatar
That's the belt I have but it wouldn't get close to fitting with those pulleys. It should get me around 7-8 psi
Old 04-22-2014, 03:48 AM
210guy's Avatar
Ok so I finally got it in by turning the crank. Seriously thought the belt was gonna snap lol but it didn't so I'm good. Thanks for the tips guys
Quick Reply: procharger pulley belts??
