How do you guys check fuel pressure with aftermarket rails, an lines, and regulator
Old 05-26-2014, 05:31 AM
703 CAMAROSS's Avatar
Default How do you guys check fuel pressure with aftermarket rails, an lines, and regulator
I just got done installing AN lines, fast rails, and adjustable fuel pressure regulator. Then I realized how do you check fuel pressure with no Shrader valve now? Any help with this? Do I need to install an inline gauge?
Old 05-26-2014, 06:37 AM
Cam72aro's Avatar
My return port on the bottom of my aeromotive regulator is 6an. I install and inline pressure tap 6an fitting with the 1/8 pressure port and check it with manual gauge.
Old 05-26-2014, 07:23 AM
98Camarod's Avatar
My regulator has a provision in it for the electronic fuel pressure gauge.
Old 05-26-2014, 10:40 AM
97WS6SCharged's Avatar
My Y block feeding the rails has a 1/8 port on it which I have the sender for a gauge screwed into.
Old 05-26-2014, 10:47 AM
rotary1307cc's Avatar
Old 05-26-2014, 01:46 PM
RonSSNova's Avatar
I found a shrader valve that screws into the 1/8" npt pressure port on the Holley regulator.
DieselOrings is where I got it
Old 05-27-2014, 11:01 AM
Ordered 1/8npt shrader valve. Thanks
Quick Reply: How do you guys check fuel pressure with aftermarket rails, an lines, and regulator
