License runs done. IAT question?
Old 07-06-2014, 01:55 AM
RonSSNova's Avatar
Default License runs done. IAT question?
I did my license runs tonight. 6 in 3 hours. Humid and around 80.
I ran 142 on my last two full passes, the track was no good for ET for me. At all.
I have my car set to pull timing starting at 130 IAT. I was seeing 150 degrees at the finish line. So my 16 base was down to 13.
I am intercooled on E85.
Am I being too conservative?
Ron
Old 07-06-2014, 04:50 AM
98Camarod's Avatar
Yes way too conservative. I start pulling at the 167*, but even then it's probably conservative.
Old 07-06-2014, 06:45 AM
yenkomike's Avatar
it is conservative but id say that's one thing you don't have to worry about while getting the et to match the mph. I have been thinking about this my self just on 93 pump . without knock sensors I worry about iat mine doesn't pull timing till 170* and will pull 10* by 220*.
sounds like its making some power.
Old 07-06-2014, 07:51 AM
samdogmx's Avatar
yes I dont pull any timing until 180 and even then its like 1*
Old 07-06-2014, 09:04 AM
forcd ind's Avatar
congrats, nice MPH
interesting pulling timing based on IAT's, never did that, usually boost related pulling timing
Old 07-06-2014, 01:20 PM
JustAFooL's Avatar
Originally Posted by forcd ind
congrats, nice MPH
That's what u had always thought but the more I have read I see more people are going off their IAT's
Old 07-06-2014, 01:38 PM
RonSSNova's Avatar
The IAT timing table is a safety valve the factory uses to combat heat soak and to keep the car out of detonation when the under hood temps go out of sight.
Remember, I'm running the stock PCM.
If you look at various vehicles calibrations, some are VERY aggressive at removing timing.
I have modified mine quite a bit, but it sounds like I'm still too conservative. Easy to change.
I do have knock sensors, they have been very quiet thus far! But I know they are functioning.
Ron
Quick Reply: License runs done. IAT question?
