1900hp 427 Lsx-Sleeper
I thought I post this up sharing latest improvement results, thanks to the guys at Steve Morris Engines for making it easier to break stuff up. New transmission is on the way.
No meth inj or even a n20 halo in front of the IC either! Not to mention that most utilize a a2w setup with 100s of HP less!!! Regaurdless, even it had all that, i would never suspect 1900HP in a truck on the streets. Even if i saw a a2w setup on it for that matter as well!! haha
siiiik build! Gonna make a lot of $$$ hustling people with that truck!
Watch the harmonic balancer when he lets off the throttle. Is it a camera trick or does it actually look like the balancer almost stops momentarily around the 3:59 mark. You just know there is some crank twisting going on between full power and then shut throttle. It's also impressive to see the tubing swell as it pressurizes.
