ls3 heads or prc heads
hey guys I wanna know the best head out that performs well for a turbo build. 2 heads in particular are the spdc ls3 heads. I like the cfm they are putting out. and I know a turbo is all about velocity and airflow. then there are the prc 247cc heads. they have flow well also. well first here's my build in the making. a stock block 408 cam 233/235 113 lunati rotating assembly. pt94mm f trim 1.0 a/r t6 holley ls tunnel ram intake 92mm tb. all of this is goin in a 3rd gen Camaro th400 9in 3.50 gears. now what head will be best beneficial for a hi hp boost motor? I can spend less n get the ls3 heads or spend a lot more and get the prc heads. or is it just a personal preference? I've been doin some research and I came across guys with FI setups running the stock heads but just working em out n making crazy power. since I did that I was leaning towards the ls3 heads. but if yall have another opinion or can explain to me whats the best route to go with I will follow suit
Restricted User
The best route is whatever is easier on the wallet.
You didn't specify your goals, but chances are any of the stock castings, even cathedrals, with a good port job will still fit the bill.
