How much power can I make with this 94mm turbo?
Would like to know what kind of power will this turbo capable of making to the wheels. Set up consist of 434 CI with mast LS7 285 heads and turbo is a Gt5594 v3 billet 1.40ar. What do you all thing I can put down to the wheels?
Restricted User
Realistically about 1400whp. Smaller motors would be able to produce a lot more power. I could see something in the sub 370 range breaking 1500whp with that turbo.
Question is how much will your chassis hold. All the power won't do any good if your getting run down by less power and less turbo car. Guys with 85-88's are going 4.50's at 3300 so unless you plan to go 4.20's or something I think you should keep the 94 and beat on it.
