The Super Budget Stock LS1 Turbo Build
So I Have a 1999 Camaro SS, Lid, exhaust, Custom Tune... Best pass so far is a 13.3 @ 107 2.0 60ft on street tires, not terrible... But all the rage of being boosted has gotten to me lol! So I have gotten a great deal from a buddy whose looking to go a different direction in his setup, so we struck a deal and I'mTaking his turbo kit! Basically I'm getting a hotside kit that retains AC(my DD so very important lol) with stock K member, also the cold side, oiling etc. However this is going to be a CHEAPPP build, as in pretty much a stock LS1! Looking to make ~450-500whp on a stock engine and stock CR!
My parts list as of now:
Phamspeed Hot side piping
Cold side piping and intercooler- Ebay
JBA Shorty's Powdercoated
Tial 44mm Wastegate
Turboxs RFL BOV
Manual boost controller- Ebay
BTR Hardened Pushrods
BTR .560 lift springs
Walbro 255
Siemens Mototron 60# Injectors
Turbo will be a ~ T70 .81 A/R (still deciding)
Stock Heads
EFI Live Custom Tune
Should be fun/interesting lol
I'll keep updating the progress and pics!
Btw this is my For Sale Thread for things I'm trying to get rid of!
https://ls1tech.com/forums/parts-cla...ellow-lts.html
Tial 44mm Wastegate
Turboxs RFL BOV
Walbro 255
Stock Heads
Entertaining two different turbos right now! Thoughts?
TURBO SPEC:
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .80 ar
Compressor Wheel diameter 76.80mm / 102.35mm
Turbine Wheel diameter 72.78mm /64.20mm
Exhaust trim: .81ar
Turbine flange type: t4 flange
Downpipe flange type : 3 inch v band flange
or
Intake :4 inch
Outlet: 2.5 inch
Compressor Wheel diameter: 72.35 /102.86
Turbine wheel diameter : 68.40 /79.00
Exhaust trim: .96 ar
Downpipe flange type : 3" v band flange
TURBO SPEC:
Intake :4 inch
Outlet: 2.5 inch
Exhaust trim: .81ar
or
Intake :4 inch
Outlet: 2.5 inch
If you decide to go with the t72. I would get the .81 housing over the .96 exhaust housing. The exhaust flow will match the compressor flow better. It's gonna be lighting fast spool. That's for sure. I'm really considering a t72 with a .81 ar exhaust housing for my stock lq4.
Day 3
Attempted the horrifying motor mount replacement today!
Actually went much smoother then anticipated, took me and a buddy ~2 hours to complete!
Also decided to grind down the rust under the battery tray and repaint it so it doesn't get any worse in the future! While waiting for it to dry I popped off the drivers side valve cover to see how things look and get ready for valve spring and PR
So after a very busy work week and being out of town a couple days, we were back at it today finally and got some more work done
Got the oil pan tapped
Headers and crossover pipe in
Most of the coldside pipe fitted and the GIANT intercooler in
Custom/Hacked Walbro 340 fuel pump assembly
Try to ignore how filthy the car is right now lol
