oil return (turbo) fitting location
where are you guys putting your oil return fitting, esp in an "A" body car
I wanted to try and weld in the fitting before installing the engine so I don't have to test fit, then remove the engine again
turbo will be on the pass side-I will pick up the feed off the orig. sensor location, or down by the filter, not sure which is the best location, prob the same vol. of oil??
