Couple questions about the 5.3 swap into f-body
Old 08-20-2014, 05:53 AM
JustAFooL's Avatar
Default Couple questions about the 5.3 swap into f-body
Soon to pull the old motor out and put on my l33 for my gt45 build. Just a few questions that I can't seem to get good answers on. Be on the lookout for the build thread very soon.
- Is the alternator relocation a must?
- Do I need to swap to an ls1 oil pan?
- What size drain for the turbo as I'd like to have it in before the motor is in. I was thinking oil pan so I wouldn't have to worry about hitting balancer or belt? Threading it in ok since I have no way if welding aluminum?
Old 08-20-2014, 08:58 PM
JustAFooL's Avatar
Can nobody answer these questions? I can't find a STRAIGHT answer anywhere..
Old 08-20-2014, 10:06 PM
topgun542's Avatar
Alright so, i swapped a 4.8 into my fbody. The alternator is a must because it sits to high and will interfere if you are using the stock one from the 5.3. Just use all the accessory and use a manifold that goes over the alternator if using ls1 accesories.
I Dont think the truck pan will fit in an fbody. i swapped from the truck one to an ls1
and i used a -12 to return the oil to the pan
Old 08-21-2014, 05:12 AM
JustAFooL's Avatar
Thanks my man, that all I needed to know.
Old 08-21-2014, 04:15 PM
ToxicWS6's Avatar
/\ good info, if ur doing a 5.3 swap and ur pulling ur ls1 out, just strip 5.3L to a longblock and swap everything off ur ls1 to it and everything should bolt in no issue, just treat the 5.3 long block like an ls1 long block and u shouldnt have any issues, had my ls1 out and 5.3 in in a weekend with some help from a friend, through the hood too! lol
for questions u can swap ur alternator to factory ls1 spot but depending on ur turbo build u may have to re located it again, so see what kit u plan on using and go from there
ls1 oil pan is a yes and i use -10 drain welded (could easily drill and tap also though) to the side of my pan and no issues at all
it will be a fun build, loved mine!
Old 08-21-2014, 09:08 PM
JustAFooL's Avatar
Thanks for the reply man. As far as the alternator goes, I'm going to fab my own hot and cold sides. I knew to take all the factory accessories off the LS, I seen a swap from CBR performance but really don't want to pay 200$ for for something that I really don't need. Soon to start a thread, I got my Tick cam in today..
Old 08-22-2014, 08:10 AM
ToxicWS6's Avatar
awesome man, look forward to seeing another 5.3L build
Old 08-22-2014, 05:47 PM
StangTamer's Avatar
If you are fabbing your own you DO NOT have to relocate the alt. Just have to cut your manifold. I cut mine as far back as i could and V-banded them, kept stock location. Just get creative, fabbing is half the fun! should be a nice setup!
Old 08-23-2014, 06:58 AM
JustAFooL's Avatar
Your kit looks great! How does your wastegate work with the placement right there?
Old 08-27-2014, 06:50 PM
StangTamer's Avatar
Sorry i've been working long hours and haven't been on.Thanks for the compliment, this is my first build and am pretty happy with the way it turned out. I have had zero issues with this placement, it will hold 4 psi no problem. I was a little worried when i did it but it's worked good so far.
Here's a couple pics of it completed also. Need to clean it up a little but you get the idea.
Attached Thumbnails Couple questions about the 5.3 swap into f-body-motor.jpg   Couple questions about the 5.3 swap into f-body-motor1.jpg
The following users liked this post:
DustinJames99 (06-20-2024)
Old 08-28-2014, 11:32 PM
JustAFooL's Avatar
To be your first build, that thing looks great man. Awesome welds and fab work. I been practicing on some tubing and I'm having problems getting decent welds. Just not consistent.
As far as using the oil pan, im guessing that i I can just the windage tray from the l33? Basically just swapping out the pan and dropping the motor in.
You didn't use any flex couplers?
Old 08-29-2014, 08:52 AM
StangTamer's Avatar
I'm not sure on the oil pan, i've never looked at the l33. No flex couplers, everything is solid mounted so i shouldnt have any flexing anywhere.
Thanks again for the kind words.
Old 08-29-2014, 09:07 AM
JustAFooL's Avatar
Did you weld your motor mounts up or what brand did you buy?
Old 08-29-2014, 10:19 AM
got-a-ls1's Avatar
haha stangtamer your setup looks really similar to mine.
Old 08-29-2014, 05:09 PM
StangTamer's Avatar
They're Spohn mounts, I got an awesome deal on them so i grabbed them up. They gave me a ton more room for the downpipe also.
Old 08-29-2014, 05:14 PM
StangTamer's Avatar
Haha nice, I don't like the look of the alt up top so i took a look at it and thought, **** i can make this work! I do kind of regret not going under the sway bar on the passenger side though. I need to make a hard coolant line like yours and get rid of the ABS.
Quick Reply: Couple questions about the 5.3 swap into f-body
