Little or No turbo lag from a single set-up....on my 390ci....Possible...?
Old 08-30-2014, 07:20 PM
LS6427's Avatar
Default Little or No turbo lag from a single set-up....on my 390ci....Possible...?
I know theres a lot of factors that go into building the perfect combo.......but what turbo size is best for the 390ci....through a 4L80E. Id like to make 800/900 RWHP.
My friend just built a single turbo T6 complete turbo kit that retains factory A/C and factory sway bar........and he said he will build me one too.....so I'm thinking of going single instead of Modular Turbo TT kit.....
But its a 100% street car......Id like to have a smooth acceleration from down low all the way up to top speed highway pulls to 160mph.......
I really don't want that big slam of boost coming in at a certain rpm....
Is it possible.....?
Old 08-30-2014, 07:59 PM
LosLS2's Avatar
I'd step down to a T4 turbo like a pt76gts for your power goals and spooling needs.
Old 08-30-2014, 08:09 PM
LS6427's Avatar
Ill be using full time E85 also......iron block LQ9.
If I can make more power that's cool......
Are you saying a T4 will be better for getting rid of lag......compared to the T6...?
S480 maybe....?
Old 08-30-2014, 09:30 PM
RatCityRex's Avatar
76mm with a t4 .96 ar.
Old 08-30-2014, 09:40 PM
Moderator
denmah's Avatar
single on3 76mm will have no lag at all on that setup
Old 08-30-2014, 10:16 PM
ZGLASS's Avatar
7685 for those cubes in my mind. I have the 7675 on my 5.3 forged motor comes on super fast on a rear mount. This its to small for the 390.
Old 08-30-2014, 11:15 PM
02LS1ram's Avatar
76mm will choke that motor up top. With My pt7675 on my 5.7 I have no lag. I think something a little bigger and a correct spec'ed cam would do you wonders I'd get together with a vendor and have them put a combo together that would work well.
Old 08-31-2014, 01:02 AM
ZGLASS's Avatar
Yes this^! a gansta s476 would be the **** on a 390 for a street car. talk to Martin at Tick he ill steer you in the right direction.
Old 08-31-2014, 06:57 AM
necrocannibal's Avatar
Same turbo here on a 383 and it has almost zero lag and runs like a freight train up top. That's where why I would look. The almost no lag full boost pull were astounding to me. Made mid 600s on 9 psi. About to go meth and biggeer pumps and up it to 18 psi. Can not wait!
Old 08-31-2014, 10:16 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
I have a Precision T76GTS for sale. It was on my 383 and there was no long as mentioned above and continued to pull.
Old 08-31-2014, 02:59 PM
LILHEMI's Avatar
billet S476 with a 92mm wheel.
Old 08-31-2014, 03:19 PM
LosLS2's Avatar
S480 maybe....?
yes and yes.
The trade off being a lower power curve.
The following users liked this post:
cammednnbs (03-09-2024)
Old 08-31-2014, 03:27 PM
LosLS2's Avatar
Yeah, I believe that the GTS comes with the 85mm turbine wheel. The 75mm turbine wheel is too small.
Old 08-31-2014, 03:30 PM
LosLS2's Avatar
That's a class turbo which would give him more RPM up top but laggier down low due to the big wheel.
Old 08-31-2014, 03:58 PM
ZGLASS's Avatar
The s476 won't be laggy on a 390 auto. I have a six speed rear mount 7675 . 96 on a 5.3 and it spools real fast.
Old 08-31-2014, 04:04 PM
LS6427's Avatar
The hard pull up top is most important to me. I'm sure that if the trade off was some loss of down low power....it still would be all the tires can handle from a dig or from a slow roll into the throttle.......
Old 08-31-2014, 04:10 PM
LosLS2's Avatar
You are talking apples and oranges. Your turbo has a 75mm turbine vs the 92 or whatever mm of the s476 that I'm talking about. If I'm not mistaken,there are smaller turbine wheels available for the S400 also.
Old 08-31-2014, 04:11 PM
LosLS2's Avatar
The hard pull up top is most important to me. I'm sure that if the trade off was some loss down low power....it still would be all the tires can handle from a dig or from a slow roll into the throttle.......
How high do you want to spin it?
Old 08-31-2014, 04:19 PM
Hi-Po's Avatar
Your thread title and this post contradict each other.
Old 08-31-2014, 04:27 PM
LosLS2's Avatar
Originally Posted by Hi-Po
You're thread title and this post contradict each other.
Glad I'm not the only one that noticed.
Quick Reply: Little or No turbo lag from a single set-up....on my 390ci....Possible...?
