Stock 48 at Drag Week
#102
9 Second Truck Club
Thanks guys! Yes the engine combo is as budget as it gets but the car is another story. Lol
Just restoration alone on this car is 20K+ then add up the suspention, wheels, fuel system, saftey equipment, and my 100's of hrs in time and it gets expensive. I honestly had no other option than to go budget on the engine combo after all of that. However a guy could throw this combo into a fox body or mid 80's car around mid 3k lbs and have really cheap deadly combo. I think a 78-82 malibu would be my choice if I had it to do again.
#103
I thought your name was Jason? Ha!
I watched a bunch of day 6 last night and found your 8.22 run. Your car really does look good.
And of course runs even better.
Hot Rod should come to you and do a feature.
How was the availability of E85? And how was the driving part?
#107
9 Second Truck Club
Extra I take it to 6800 and it picks up a little. Car was actually on the 7k rev limiter thru traps on the 8.22 run. I have it set for 7k but it comes in around 6850. I never mentioned it earlier but on the drive the bumpy roads with trailer etc settled my springs and caltracs were out of adjustment. On the 8.22 pass car pulled to the right and I had to peddle it back to about 2/3 throttle and steer it back strait. Think car had a high 0 to low teen on it if I had got a chance to fix that and bump limiter up. They just fked us around too long in staging lanes and ran out of time. The tb and intake are stock from a 2002 4.8L truck.
Thank you!
Thanks! Im so happy everything held together and got it done. Had some trans problems but we got that fixed.
#108
What gear/tire again? I think I might have a problem with either converter or trans. I was hitting the limiter right after the traps at around 150mph 6800 limiter 28"/3.27.
I am really hoping to get into the 8s myself this week so any tips/advice would really help! So far 9.4@149 but I haven't had a strong launch yet. 1.6 of of 5psi. What are you seeing off the footbrake. I am afraid to go too high if it just turns into a brakestand haha.
#112
#114
Congratulations. Awesome work. Lots of people happy to see this!!!!
I was wondering what your trans problem was and where you swapped or repaired the issue?
THank you btw. ALot of my coworkers tend to call LS engines crap!!!!!
They certainly didnt have anything to say when you won!!!!!!
THank you.
THank you.
#120
9 Second Truck Club
Thanks guys! Yes the band in the transmission broke first run in Topeka. It was a major setback but we got it fixed. Luckly I was able to make the pass in hi gear as well as drive the 320 mile leg back to Ok with just hi gear. Was sketchy pulling trailer thru all the towns and up the hills with just hi gear but somehow we made it!
