Screamer pipe vs plumbed back
Old 09-12-2014, 06:15 PM
EV1LR8's Avatar
Default Screamer pipe vs plumbed back
I would like to know if anyone has done any testing when it comes to running a Screamer pipe or having it plumbed back in
What sort of power gains if any have guys seen from going a screamer
looking more at street / strip cars
My set up is a 408ci, S480 96mm rear 1.32ar
Cheers
Old 09-15-2014, 05:43 AM
EV1LR8's Avatar
any one ?
Old 09-15-2014, 06:56 AM
ramairetransam's Avatar
whats a screamer pipe ?? never heard anyone on here use that term or word.
Old 09-15-2014, 07:37 AM
69-chvl's Avatar
Cant comment on power but I have 2 w/g's screaming and its not as loud as I thought it would be. Squealing tires makes make alot more noise
Old 09-15-2014, 07:40 AM
TDagen's Avatar
He is referring to a wastegate dumping to atmosphere vs plumbed back to the downpipe/exhaust.
OP: Personally I have never plumbed one back to the exhaust, I always leave it open route it towards the ground and let it "scream". I figure it helps relieve some back pressure that way...
Old 09-15-2014, 09:39 AM
willizm's Avatar
I don't know if there are many people that have went from recirculated into the exhaust to a wg dump. I'd imagine it's very dependant on how much boost and how large your dp is. If it's a big 4" deal and you are not pushing the single that hard then it probably wouldn't make much of a difference.
Old 09-15-2014, 10:26 AM
lt170chevelle's Avatar
I originally ran a 1 3/4" dump pipe of my wastegate and was pretty raspy. After a week I plumbed it into my 3 1/2" downpipe. It felt slightly slower but had sounded much better and could hear the turbo whistling. If I had to redo it, id run it seprate with a small glasspack or something just to knock out the raspiness. lol But its one of those preference things, made it sound like beast only at wot I just didn't like the sound of an open pipe
Old 09-15-2014, 10:28 AM
stevieturbo's Avatar
Cheers
Unless your exhaust is very restrictive, it wont make any difference.
Old 09-16-2014, 04:11 AM
EV1LR8's Avatar
the dump pipe is 3.5" and aiming to run 18-20psi
Old 09-16-2014, 05:53 AM
SirNemesis's Avatar
I went from screamer to plumbed back and noticed no difference in power, but it sounded much nicer. Same 3.5" dump/exhaust. Might be a different story at bigger power levels.
Old 09-16-2014, 06:20 AM
The noise can be irritating inside the car if vented to atmos.
I ended up making a couple of small silencers instead which killed the worst of the noise
Old 09-16-2014, 06:32 AM
wolfinsheepsclothing's Avatar
Gains will be marginal (if at all). Personally, I think open dump tubes sound great
Quick Reply: Screamer pipe vs plumbed back
