gt45 failure no blow off?
i just finished building a junkyard 5.3 with a ebay gt45 for my sand rail. i have had it out on the sand one time for about 3 hours of tuning. the oil seal in the compressor housing is leaking now.
i am running 12 lbs of boost non intercooled. i did not have a bov in the system and the turbo would bark pretty bad when you chop the throttle under full boost. now i am fighting this oil leak from this compressor.
is it possible that running without a bov knocked the seal out?
thank you
thank you
the drain line is a -10 hose and fittings. the feed is a -4 with out a restrictor.
the turbo is mounted over the transaxle and does not provide a nice path for a drain. the return line has about a 5 inch drop over about 28 inches of length. i have a fitting welded into the side of a f body oil pan about 1.75 inches down from the pan rail. i believe it is right about oil level.
when i have the car sitting and idling for 10-15 minutes while working on my tune is when i really start to notice it as oil starts to puddle in the intake.
