Steam Ports (tap to 1/8npt?)
I'm building a stock 5.3/gt45 turbo to go in my vette build in my sig. I want to go 4 port steam vs the stock 2 port with the back 2 closed off. Has anyone drilled and tapped heads for 1/8 npt and used 1/8npt to -4 fittings? it seems much cheaper than any other setup out there and looks easy enough to do. I have searched pretty hard and have not seen anyone doing it.
thanks in advanced
thanks in advanced
stock truck for the moment but probably go holley or edelbrock high ram at some point. I can make a stock 4 steam port or 2 2port setups(shipped my 2 port to a guy in trade for a 4 port his never showed up) work but thought all braided line look better and not have any more into it than any other setup.
i been doing this for years.
1/8npt to 3/8 barb. in stainless fittings.
all of my cars have these fittings. also use Ys to connect the lines.
these fittings can found on ebay. sold by beer/brewer supply vendors.
and there. cheap. a 4 pck ofthe fittings is only like 10-15$ w shipping. about as much as the brass versions. the stainless Ys are only a few bucks also. hose is just 3/8 coolant lines.
less than 30-40$. and the steam port has the benefit of being a larger bore.
if it helps any idk. i would think it may move more water away if anything.
but works just as good as the high dollar setups i think. and the barbed end and hose clamps. that hose isnt leaking or going anywhere.
