heads for boosted 408
Hey guys just want some info on a pair of decent ls3 port heads.
Im after a set for my twin turbo 408. 4 bolt head looking to run 20-25psi boost. So needs to have a decent deck thickness..
Im thinking a set of trickflow 255. What are peoples thoughts has to be rectangular port.
You can easily make them or order them from ERL performance and weld them on, you'll be glad you did.
The weak alum block will thank you cause their decks are kind of thin and will else keep you from looking at your MLS head gaskets very often.
http://www.trickflow.com/partdetail....1&autoview=sku
Thanks for the replys
My block is actually a iron ly6 so will be stuck with 4 bolt.
And yeah the trickflow seem the way to go just wanted a few more opinions to make me feel there the right choice.
I might talk to liljohn he has already supplied most of my parts already.
Cheers
Cheers
As others have said the TFS 255 heads are badass. I have a set that was done by TEA and I would get the 6 bolt Incase you ever step up your block later it's only $100 more and you'll kick yourself later if you don't get them. John will likely get them done through TEA as well if I had to guess
