Help Me build my first turbo Car, Huron Speed kit ???
Old 10-05-2014, 07:10 PM
railmule's Avatar
Default Help Me build my first turbo Car, Huron Speed kit ???
OK guys Ive been reading and reading some more on turbo kits,, I think i would like to buy a Kit because I cant weld and dont really trust anyone around my area to do it... I have been looking at this kit.
Huron Speed V2 Single T4 Turbo Kit
Item #: v2turbokit
Add Turbo: Turbonetics TC78 .96
Downpipe Option: Standard 3" Through K-member
Add Wastegate: XS-Power 44mm
Add BOV: XS-Power 50mm
Add Oil-Lines: Both Oil Feed & Drain Kit
Add Coating: None - Raw, Polished Stainless
Add 4" Air Filter: Add 4" Air Filter to fit all 4" Inlet turbos
Add Turbo Blanket: None
Add Dual Fuel Pump Kit: None
Add Fuel Injectors: None
Shipping to: USA (mainland 48)
$3,574.99
Subtotal: $3,574.99
Ive got about 6K to speed on turbo kit and suporting mods...
this is my setup now on car...
stock bottom 346 80k
PRC Stage 1.0 LS6 CNC Ported Heads lunati double springs
ls6 intake
LT's Borla XR-1
227/235 111lsa cam over 600lift
s60 rear end 3.73gear
low mileage 4l60e
3200 stall
parts i have collected for build..
317 heads
80lb siemens deka injectors
Walbro 400
ARP head studs
So some of the questions i have is,, can i use the PRC heads with turbo?? or too much compression?? Would cam listed above work?? like i said i am a virgin to the turbo world... Any help greatly apriciated..
Goals are fun *** street car,,, 500-600hp still able to drive highway speeds 2-3 hour trips,,,,, dragstrip 20passes a year just for fun...
Old 10-06-2014, 05:03 AM
LS1Tech Sponsor
Superman09's Avatar
First off, you will be very happy with our V2 kit!! The turbo kit will work just fine with your current heads as well. Make sure you have enough fuel for your power and the tune is in good shape and you will have a very enjoyable and responsive set-up! Cam will work, may not be the most ideal but will work for now if you do not want to swap it out to something ground specifically for the set-up. Your goals are very easy to hit with the kit and set-up as well, no problem at all!
Let me know if you have any other questions and I would be more than happy to assist you. We have the kits on sale on the website right now and in-stock ready to ship!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Quick Reply: Help Me build my first turbo Car, Huron Speed kit ???
