boost plus spray
boost plus spray
So I have had a gm crate lsx block 376 for a few years. It has a small blower cam valve springs and head studs. Right now with 14 lbs of boost its around 730ish HP. Who thinks I should spray a 50 to 100 shot. I've been suprised at what this motor has done already.
Just remember to jet the fuel on the rich side since you will typically pick up more than the rated nitrous jet when mixed with FI. For example I spray a 70 shot (40N @ 900psi) that makes 110 wheel on top of 10lbs of boost that makes 600. Also remember to pull some timing and sneak up on it. Let us know what you find.
In addition, the N2o tremendously cools the charge .... The lower IATs increase the power by default and that's were additional power comes in.
