need a new tune if using a 2 step?
As the title states.. I have a MAF tune right now on my boosted M6 gto. If I added a MSD 2 step would I have to have my tune changed?
Thanks
Thanks
Not required but it can help if just adding the 2 step doesnt achieve results.
I used the msd 2 step on my 04 gto m6 with a large frame 76mm rear mount. No additional tuning just installed it and pressed go. It would make 10psi almost instantly at 4k rpm, also sounded like a full auto 12g going off behind my car while it blew some nice fire *****.
Switched to a front mount 7875 t netics with the rest of the car being the same and had the same results.
Now with the th400 I can only foot brake till about 3k rpm so I set the rpm on the 2 step to 3k and it will build 5 psi rather quickly. This is all without any additional tuning.
I looked at my timing when on the 2 step just out of curiosity and it was in the mid 20s. I'm sure if I retarded it a bunch in that area I mighy get 10psi or even more at the same rpm. Maybe one day next season I will play around with it and see if I get some results.
