Holley HP Question
Old Nov 9, 2014 | 01:16 PM
THADD's Avatar
Default Holley HP Question
I am ditching my BS3 this Winter and going with the Holley HP system. All I need to get is the computer and the LS harness correct? What is the best price people have found it for?
Old Nov 9, 2014 | 01:22 PM
denmah's Avatar
Moderator
computer and holley specific harness, for your engine, make sure you get 24x or 58s right of course, members have chimed in before that there are great places to buy these from and places with the best support over the phone etc, so i will let them chime in on that
Old Nov 9, 2014 | 02:01 PM
toxic99's Avatar
Not positive but think inj harness separate as well.
Old Nov 9, 2014 | 02:59 PM
THADD's Avatar
Most of what I see is all separate. That's why I am a little confused on exactly what I need to get.
Old Nov 9, 2014 | 03:30 PM
chevydillan's Avatar
I was just about to ask this same question .
Looks like 550-602 would be the correct part number . Am I right?
Old Nov 9, 2014 | 03:48 PM
a98ws6's Avatar
In for the same question.
Old Nov 9, 2014 | 03:51 PM
THADD's Avatar
Originally Posted by chevydillan
I was just about to ask this same question . Looks like 550-602 would be the correct part number . Am I right?
It appears to be to me
Old Nov 9, 2014 | 04:34 PM
boss79z's Avatar
Check out yellowbullet. They have a ton of threads on it there.
Old Nov 9, 2014 | 06:55 PM
Camaro9969's Avatar
Idk if you have your racer discount set up through jegs but if not DO IT! best pricing hands down
Old Nov 9, 2014 | 07:01 PM
a98ws6's Avatar
Can anybody set that up with Jegs?
Best price I've found is $1,001.
Old Nov 9, 2014 | 07:18 PM
^^^ where? Pm me if you want to
Old Nov 9, 2014 | 07:21 PM
THADD's Avatar
Originally Posted by a98ws6
Can anybody set that up with Jegs? Best price I've found is $1,001.
Where
Old Nov 9, 2014 | 09:07 PM
a98ws6's Avatar
Thats just the HP ecu..
Old Nov 10, 2014 | 05:58 AM
turboventura's Avatar
Injectors are seperate, input/output harness is separate. Converted my gen1 with their kit and extra sensors like fuel pressure and oil pressure were seperate as well, don't know if that's included with the LS harness. One thing to consider is the tech support of jegs and holley, in my experiences it wasn't that great, if you buy from more of a race shop you can often get better base tunes and better tech support should you run into anything.
Old Nov 10, 2014 | 06:52 AM
copo-rat's Avatar
Why are you ditching the BS3?
Old Nov 10, 2014 | 07:31 AM
98Camarod's Avatar
Are you not going to the davis technologies traction control? Something to think about is what all you need to be controlled. The dominator has way more control with the inputs and the PWM outputs. Boost control, fuel pumps, fans, traction control, nitrous controller, etc. If you don't need them, then it's the same software.
I was going to order the hp as well, but I would be to close to the limits of the inputs and wouldn't be able to add the traction control down the road. So I'm just going to get the dominator from the get go.
Old Nov 10, 2014 | 07:41 AM
forcd ind's Avatar
there are so many diff combos, injector types, reluctor types, LS1, LS2, etc that you need to order correct harness's
They have a one part #(HP) for basic LS1 24 rel. that has all in one, but as you get away from that then you need to customize
Old Nov 10, 2014 | 07:49 AM
oscs's Avatar
Call mike@skspeed he had the best pricing I could find and his help getting everything I needed was great.
Old Nov 10, 2014 | 08:26 AM
THADD's Avatar
I just think the Holley is more user friendly for someone like my self that's not an actual "tuner"
Old Nov 10, 2014 | 08:32 AM
THADD's Avatar
Originally Posted by 98Camarod
Are you not going to the davis technologies traction control? Something to think about is what all you need to be controlled. The dominator has way more control with the inputs and the PWM outputs. Boost control, fuel pumps, fans, traction control, nitrous controller, etc. If you don't need them, then it's the same software. I was going to order the hp as well, but I would be to close to the limits of the inputs and wouldn't be able to add the traction control down the road. So I'm just going to get the dominator from the get go.
I have bounced around the idea of HP or Dominator but I already have a Boost Leash that I like and all things like fuel, fans, etc I have on switches and are all turned on before the burnout and gauges that read everything
