1K+hp guys...what fuel pump you running?
I think im going to pull the trigger on a Magnafuel 4303. Just trying to decide on injectors. Looking at any and all ideas. I keep seeing Bosch 160's a lot, but the prices are anywhere from $550-1600?? Where and which ones to buy? Also like the FIC and ID injectors but not sure which ones would get the job done from them?
stock sumped tank with a 4303 and ID 1300 injectors. absolutely no problems other than my relays wanting to melt under heavy abuse. the 4303 is a beast.
#33
Primary pump when not in boost is an in tank Walbro 255. Then my aux. pump is a MF4303 activated on a 2 psi hobbs switch. E85 w/ Deatschwerks 96lb inj. (108lb at my base fuel psi of 65). Not sure on dyno numbers but its a 155-160mph car. Injectors are maxed out at this level though.
#34
When the aux pump is activated, does it turn off the 255 or do they work together?
#36
dual Bosch 040 before needed a BoostaPump and ID1600's for GTS76 turbo on e85 to go 162mph....
current PT8847 runs dual walbro 450lph e85 friendly pumps on e85...
Haven't maxed out the turbo since I have a stock LS1 crank inside with good rods/pistons; however it made 1050rwhp on 14psi/1060rwtq..... been up to 20psi a few times in 4th and 5th gear in the 1/2 mile racing. It pulls hard on that setting.
we are lucky in NorCal and I've found a couple e85 stations that are 83-85% year round.
#37
dual Bosch 040 before needed a BoostaPump and ID1600's for GTS76 turbo on e85 to go 162mph.... current PT8847 runs dual walbro 450lph e85 friendly pumps on e85... Haven't maxed out the turbo since I have a stock LS1 crank inside with good rods/pistons; however it made 1050rwhp on 14psi/1060rwtq..... been up to 20psi a few times in 4th and 5th gear in the 1/2 mile racing. It pulls hard on that setting. we are lucky in NorCal and I've found a couple e85 stations that are 83-85% year round.
