decided to upgrade my turbo.
decided to change my turbo from my tc78 .96 to a borg warner s380r with a t4 housing 1.25 ar with a race cover should be a better match for my 6.0 .
anyone have any experience with a 380 on a 6.0. thanks.
http://i35.photobucket.com/albums/d1...inTurbos31.jpg
Now, keep in mind, these names and categories were mainly started and maintained by the aftermarket. These are not Borg Warner part numbers or anything
The confusing part comes in when the aftermarket starts trying to differentiate a t4 housing s400 80mm compressor turbo from the same thing with a t6 housing with a very simple part number. We played a big role in this many years ago. Basically the only difference between an s380 and an s480 was the turbine housing/wheel. (83mm and 87mm wheels use a slightly different CHRA, but the shaft size and internals are all the same as 96mm). This gets confusing, because an s362 is the same as an s366 with a larger compressor wheel, but an s375 is a totally different chassis. The only reason you know it's an s400 CHRA and not an s300 is the fact that nobody puts 75mm compressors in s300 housings due to airflow restrictions.
The problem with "380" was that it didnt tell the whole story anyways. there are still many different a/r sizes available, multiple turbine wheel sizes, etc. You could have an "s380" with a t4 1.0 83mm turbine, a t4 1.25 87mm turbine, or a t4 1.10 96mm turbine. Alternatively you could have an "s480" with an 83mm turbine .90 a/r t6 housing, or a 96mm turbine and t6 1.58 housing. It just wasn't descriptive enough, and left too much information out.
You can see how it all got pretty confusing. For these reasons we have abandoned that way of thinking. Now, if it is an s400 sized CHRA, with an s400 turbine wheel/shaft, the part number starts with 4. The compressor inducer follows. So, what used to be called an "s380" is now an "s480 with a t4 housing". If it is a standard cast borg unit we call it "s", if it is our billet unit it would be "b480". If it is our batmowheel we would call it a "bmw480", etc.
Hope this helps.
Jack
Jack
the t4 inlet and 4" downpipe vs the 5" is what I wanted. everything else was fine for me.
Jack
