4.8 TTiX iron block build stroke it or no
Old 11-21-2014, 02:36 PM
rkreigh's Avatar
Default 4.8 TTiX iron block build stroke it or no
looking for good piston options for a small 3.8 bore block turbo piston
I do have a lunati 4.0 crank and 6.125 H beam rods
and I have an Ls6 I can tear down to use the stock 3.6 stroke if needed
but I'm wondering if using the stock short stroke 3.22 crank would be the hot ticket to rev it a bit higher and stay in each gear longer under boost
I haven't found too much aftermarket pistons se up for the short stroke crank
or a forged short stroke crank would be cool too
looking to make sure I stay in the sweet spot of the t3/t4 58/62 turbo with 3" down pipes
also looking for advice on a good cam
I've got an rpm auto 3.45 gear and triple disk lockup torq conv 3200 stall
trying to run about 1000 k hp at the tire
and I can used E85 if needed
I have bosch FIC 127 injectors and will be running a haltech s2000 ecm
and also alchy Julio injection system now controlled by the haltech
thanks for any advice, hoping santa brings the right parts
Old 11-22-2014, 02:00 PM
rotary1307cc's Avatar
Why do u need a special piston? Just use a typical 1.30x CH piston and a 6.3 rod
Quick Reply: 4.8 TTiX iron block build stroke it or no
