anyone using corvette filter/regulator
Just as the title says trying to see if anyone is running the corvette regualtor filter,with a turbo set up??How much rwhp have you made thru one ,does it hold constant FP or drop off?
It is a common swap for a lsx s10 but i wouldnt try it with forced induction, there is no way to raise fuel pressure with boost so your horsepower ceiling will be really low.
Since when was boost reference mandatory... I cant speak for hp limits because I don't know but it will work just fine.
Its been years but I remember doing something like 550 whp or so through one without issues.
However, In higher hp with boost.
What are you guy using for a fuel filter?
Thanks
Ive used the C5 filter/reg under boost and it did work, but wasnt ideal. Its supposed to be a fixed 58psi, but would actually fluctuate ~50-60. Not a big deal for most NA cars, but if your fuel system is on the edge, it can risk going lean at the wrong times. An external regulator like the aeromotive above is much safer
Mighty, you might want to rethink the 340 pump in your system. They overheat with extended use (street) and shut down. For a racecar, it wont see enough run time to matter, but be aware they support about as much as a walbro which wont shut down
Yikes! Thanks for the heads up. Better sell the 340 and get a second racetronix 255lph. I have a boost sensitive switch that was going to fire the second pump under 'x' boost.
Dave
Dave
I have never heard of anyone having a problem with one, where have you seen people overheating them?
