Oil restrictor or No? Billet S480
Lots of variables here. with a -4 feed line and 60-80psi at WOT, you will normally not need a restrictor. Unless you plan on extreme oil pressure or have a smoking/leaking problem that won't go away, we never recommend a restrictor.
Jack
Jack
My opinon is if you are running a restrictor on a journal bearing turbo than you are putting a bandaid on another issue. Some guys do it and i think garret reccomends it as a "fix" for certain applications (excessive oil pressure.)
In no way would i reccomend anyone go out and buy a restrictor for their JB turbo with out do the following two things first.
A. running it without one to see if it has issues
B. upgrading or appropriately sizing your drain
