who to get turbo tune from?
Old 03-19-2015, 05:24 PM
yenkomike's Avatar
Default who to get turbo tune from?
im going to build a turbo system for a 2001 2500 hd truck it is a 6.0 all stock and I want to use a small turbo like a tc76 the engine will be all stock and I was thinking about just buying 80# injectors adding a bosch 044 pump and adding 8# boost. just for pulling on pump 93 fuel.
can I send the ecm to someone and have a tune loaded for this app or do I need a custom tune. I just want a safe tune with about 10* timing at anything more than 8# boost . preferably a sd tune. thanks.
Old 03-20-2015, 12:53 PM
scottywheels's Avatar
Originally Posted by yenkomike
im going to build a turbo system for a 2001 2500 hd truck it is a 6.0 all stock and i want to use a small turbo like a tc76 the engine will be all stock and i was thinking about just buying 80# injectors adding a bosch 044 pump and adding 8# boost. Just for pulling on pump 93 fuel.
Can i send the ecm to someone and have a tune loaded for this app or do i need a custom tune. I just want a safe tune with about 10* timing at anything more than 8# boost . Preferably a sd tune. Thanks.
dyno!!
Old 03-20-2015, 02:18 PM
DHR Darren's Avatar
Call Lang @ LPRacing in Rancho Cucamonga Ca.
His shop truck was built nearly identical to that. I'm sure he has a tune.
Quick Reply: who to get turbo tune from?
