injector size for x275 turbo
Old 05-09-2015, 11:03 AM
garethmarshall's Avatar
Default injector size for x275 turbo
What size injectors should I run on a x275 88mm turbo and 216ci motor
Old 08-20-2015, 11:08 PM
Kmspeedie's Avatar
shud b worried bout wat size shot of spray u need to light that sucker lol
Old 08-21-2015, 09:50 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
How much injector will depend on how much power you and boost you plan to make. 10psi needs far less than 30psi.
Old 08-21-2015, 10:05 AM
Restricted User
JoeNova's Avatar
He posted this exact same thing a few months ago.
Old 08-21-2015, 11:35 AM
Forcefed86's Avatar
32 40lb injectors should do it.
Old 08-21-2015, 12:42 PM
IronBlocked's Avatar
Moran 500s
Old 08-24-2015, 07:22 AM
Old Geezer's Avatar
Talking Hehehe...
Originally Posted by IronBlocked
Moran 500s
Pretty much what I'm thinking!
Old 08-24-2015, 11:14 AM
xxxPOPExxx's Avatar
Moran 500s
Aren't the Moran 500 lb/hr just 325 lb/hr with the pressure cranked up?
PART# MRE 325A2
Static Flow Rate = 325
Impedence = Low
Resistance = 1.6
Fuel Pressure Rating = 43.5 psi
Nozzle Style = Atomizer Disc
Spray Angle = Large Fog with 45 degree Vapor Cone Pattern
PART# MRE 500A2
Static Flow Rate = 500
Impedence = Low
Resistance = 1.6
Fuel Pressure Rating = 90.0 psi
Old 08-24-2015, 11:47 AM
TRIXLSXSUPRA's Avatar
PART# MRE 325A2
Impedence = Low
Resistance = 1.6
PART# MRE 500A2
Impedence = Low
Resistance = 1.6
I believe the Morans and Billet Atomizer 3 inj are adervtised the same basically like what you posted 325pph @ 43.5psi vs 500pph @ 90psi
The newer Billet Atomizer 4 are supposed to be built to your specific needs pph @ your preferred psi i believe i didn't speak to them regarding anything larger than 550pph for my application
Old 12-15-2015, 05:40 PM
I did post this before. But only got a few answers. I believe in hearing more than one or two opinions. I was thinking of going id 2000's
Old 12-15-2015, 05:49 PM
Sorry been off forum for awhile. At the track or racing we are looking around 1600 rwhp. I talked to a fellow member on here and he said they made 1400hp at the wheels on a dyno at 18lbs of boost. Almost exact same setup as mine. This is also a road car running on pump gas. So should I run a set of 200lb on track and a separate set of rails and injectors on the street? Or just try to run id 2000's all the time?
Old 12-15-2015, 05:58 PM
My mistake it's a 416 ci. Lol damn typo
Old 12-16-2015, 01:32 AM
8 Second Truck Club
Blown06's Avatar
Skip the moran 500's and just go straight to the new Atomizer 3 700 lb/hr injectors. Should be able to supply enough fuel.
Old 12-16-2015, 06:26 AM
Will they handle street applications too?
Old 12-16-2015, 03:58 PM
vinceI's Avatar
You won't need anything over a 200 lb injector. 160s would be borderline on gas.
Old 12-16-2015, 05:42 PM
I was leaning towards I'd 2000's. Thanks again guys
Quick Reply: injector size for x275 turbo
