Building my own meth tank. What do I need for the corrosion?
Old 07-03-2015, 05:25 AM
stevieturbo's Avatar
With a tank that shape, could got a small fire extinguisher bottle and used it
Old 07-03-2015, 12:39 PM
jrpimp00's Avatar
LS1Tech 20 Year Member
How are you going to fill that up when the bumper is on?
Old 07-03-2015, 11:33 PM
SpeedJunkee's Avatar
The PVC is lighter, easier to work with to plumb the drain, low level sensor, and fill point into. Plus a small fire bottle would not hold the 1.4 gallons the PVC does, and a large fire bottle would not fit at all.
I have plumbed a port in the top, then put in a brass hose barb, then got some 3/8 nylon line and ran it to a fill port in front of the radiator. I'll get some more detailed pics later once it is all done.
The plumbers goop should be good and dry tomorrow. Really, all I am waiting on is a pigtail harness to get to me to mate up the wiring for the low level sensor. Should have that on Monday.
Quick Reply: Building my own meth tank. What do I need for the corrosion?
