Summer heat and racing
Short of avoiding racing till the mine shaft air comes back to atco, any advice on racing with a turbo car?
prob gonna be ~80*, and 70% humidity, but, need some baseline pulls on car. WOT AFR is super rich ~10.8-11.0 area and timing is under 20*, no meth/water injection just a 4inch core FMIC.
Really worrying over nothing but don't want the damn thing to melt down on me, or worse, run 12s.
I like to blow mine up around May... Then it's back together late August for cooler weather.
What fuel?
Meth/water inj never hurts and is cheap and easy.
I'd have timing more towards 15* at moderate boost and 12* at 18+.
Watch coolant temps closely before runs. Check plugs, make baby steps.
What fuel?
93 pump tuned, and I only have a 14gph nozzle which coupled with an already fat WOT I think will hydrolock the poor thing. (meth/h20 system is there cause I thought IAT would be bad, never used so far)
Contemplating splashing some 100ll or 100 pump in say a half tank of 93
Restricted User
Depending on how its tuned, you could dial back your base fuel pressure 2-3 psi tp lean it out a touch and then spray the water and meth. The water alone has a ton of cooling/detonation resistance benefits.
