does MBC make turbo spool faster?
I've been having problems with my wastegate, so I order a new tial mvr 44mm and it came with a plethora of springs. I'm only wanting to run 10psi, I was going to just run a 10psi spring in the wastegate and ditch my hallman pro MBC. I thought I read somewhere that a MBC will help the turbo spool faster. Just didn't know which would be better, to just run the 10psi spring in the wastegate, or run a smaller 7psi spring and use the MBC to bring it up to 10.
Simple concept. Use a regulator and shop air and watch the valve in the WG. If you run a 10lb spring that means at 10lbs the valve should be fully open. But the WG will open slightly before 10lbs. Springs are progressive, they aren’t an on/off valve. If you have a 10lb MBC it holds all the pressure back until 10lbs. Meaning the WG stays 100% closed until the MBC pressure is met. This spools the turbo more quickly since it’s letting less exhaust bypass the turbo.
