PROCHARGER experts needed.
LS1Tech Sponsor
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
To determine the impeller speed, the following formula is used:
Maximum impeller speed = crankshaft pulley diameter (N1) divided by supercharger pulley diameter (N2),multiplied by the step-up ratio (4.10 for the P-series/D series - 5.40 for the F series), multiplied by engine rpm at redline.
The D-1SC is good for 62,000 rpm.
http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm
Aster bracket and water pump
http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm
The ProCharger front mount intercooler kit is a great way to go. If you want to see a copy of the front mount installation instructions, send me an e-mail asking for them. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
In defense of oscs it seemed like the OP was not getting the message as he kept bringing it up.
Originally Posted by The Alchemist
We've already covered that about 10 posts prior... there's no need to laugh at him, it's an honest question, and worth asking. The problem is airfolw, and he's not getting it right now.
What's wrong with bringing up the compression anyway? My tuner mentioned it should have been higher (he said that was why it fell short of expectations in the first place) and I asked if 10:1 would be okay to run with an F1 series blower. That seems like a pretty legit question. I'm going to tighten the belt a bit and see if I can get some more boost out of it for now. It seemed pretty tight already but it's hard to tell from up top.
Anyone have any cost effective front mount ideas? The Procharger upgrade seems a bit pricey for an intercooler and some piping.
#35
I'll throw in my .02 since I have some experience along these lines. My setup used to be a D1SC and I made 700 RWHP. This was on 93 octane and only 8.8:1 CR.
Look for dust on your belt. If you run your finger along the inside of the belt you'll see if you've got dust or not. Belt slippage will rob you. I also recommend a larger metal inlet elbow and a larger air filter. Those can make a HUGE difference also.
Can upping the CR help? Yes, but like others have chimed in already, that's not your problem. My 700 RWHP was on my ancient LT1 car. Your LS should easily be able to make the same. I ran a cheap EBay FMIC, and was seeing 15#'s of boost with a 3.4 blower pulley.
#36
LS1Tech Sponsor
We're the only ones that sell the Aster bracket. Thanks. Bob
__________________
#37
I didn't find any black dust or physical signs of belt slip. The pulleys are clean which was a bit misleading. I already ordered the Aster bracket, an intercooler and some piping/clamps to get everything going. I have a new K&N filter (bigger filter too) on the intake side but I'll ditch the accordion style tube that came with it for something better.
Thanks for all the help guys
#39
LS1Tech Sponsor
Thanks, I really appreciate it! Bob
__________________
#40
LS1Tech Sponsor
__________________
