TWO DIFFERENT TURBOS IN Parallel POSSIBLE
Wait. I misunderstood the question. Are those two different sized turbos?
You have both turbos running into a Y & then one outlet?
It won't make boost at wot?
(1st turbo specs on pass side)
T70 Turbocharger!!
Turbine Turbocharger
Oil cooled only
6 blade propeller
Compressor Specs :
4" Compressor Inlet
2.226" or 56.55mm Inducer
2.552" or 74.83mm Major
Compressor .70 A.R.
Compressor 75 Trim
M14 Compressor
Turbine Specs :
Twin Entry Type
11 Blade Type
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
2.894 " or 73.50mm Major
2.275" or 57.78mm Minor
(2nd turbo on drivers side)
Header:
1.65" Runner Tube
2.5" Cross Header Pipe
3" Exhaust pipe
T70 Turbo and Wastegate:
Standard T4 Flange to Manifold
0.70 A/R Compressor, 0.96 A/R Turbine
Big 4" Air Inlet, 2.5" Air outlet
3" V-Band Exhaust
Wet Floating Bearings
Oil Cooled
T70 Turbocharger!!
Oil cooled only
6 blade propeller
Compressor Specs :
4" Compressor Inlet
Compressor .70 A.R.
Compressor 75 Trim
M14 Compressor
Turbine Specs :
Twin Entry Type
11 Blade Type
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
Header:
1.65" Runner Tube
3" Exhaust pipe
3" V-Band Exhaust
Oil Cooled
You're going to have to contact them to get the specs or take the turbo off & measure it.
You never answered my question of does it make positive manifold pressure at WOT?
Secondly, you have to have the same A/R's.
If the compressor wheels are maybe a couple milimeters different, it may, may, work out somewhat OK providing the exhaust sides are identical. I wouldn't do it that way, ever, but it may work.
Why didn't you order another of the same turbo to begin with?
im sorry. it does make positive pressure. i can post a video up in a second. and in the specs it shows different A/R's
And this is my 1st build i thought i order the same tubro by typing in T70
1 turbo
2nd turbo
Compressor .70 A.R.
Compressor 75 Trim
M14 Compressor
Turbine Specs :
Twin Entry Type
11 Blade Type
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
1 turbo
2nd turbo
Compressor .70 A.R.
Compressor 75 Trim
M14 Compressor
Turbine Specs :
Twin Entry Type
11 Blade Type
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
Need to know the compressor & turbine dims on both.
The big issue is turbine sizing, providing the compressors are even close to the same. That changes airflow & pressures across the side of the engine it is connected to. That requires different fueling & timing.
correct me if i am wrong but the main issue with having 2 different turbos parallel with each other is that the turbo that spools up 1st will push back into the weaker turbo.
