Sweet Pea 1968 Chevy II Moar Door 4.8/7675/PG
#81
Found a home for the cooler in the trunk.
Built an air dam out of Vigoro plastic garden edge trim molding lol.
The air dam is both functional and easy to repair if I scrape it. It is simply screwed to a piece of aluminum angle I contoured to the bumper and fender. The aluminum angle is held in place by existing bumper support bolts. I forgot to take a picture before I screwed the plastic on.
#82
Man, what an awesome build. I have a buddy with a Chevy II that is doing a frame off resto on. He has a 5.3 he is building for it, and I am trying to convince him to do a turbo.
#83
#84
I have an 8.8 coming and the suspension parts I ordered 3 months ago are finally shipping. I was considering a methanol injection system and a two step and when I totaled it all up, it just made more sense to get an MS3 Gold Box with LSX plug and play harness from EFI source. So I ordered the Gold Box just now. Hopefully the A2W circuit will be done by the time the gold box arrives. I'm looking forward to running Sweet Pea on flex fuel.
#85
Added a few accessories while waiting for hard parts.
Its better than insurance, registration or lyin
Its better than these fake IDs I keep on buyin
Its even better than an envelope stuffed with cash
They always said itd save me, that old bible on the da-ash
I'll probably have to Velcro the Bible to the dash.
Green body color matched Kleenex box on the rear package tray and a few assorted stickers.
Just trying to go the extra mile to sell the sleeper look.
#87
Vintage 1960's cooler has been waterproofed with truck bed liner, Rule 2000 pump installed and plumbed.
Even the drain line has been plumbed into the ice box.
Rule 2000 pump flows plenty enough to keep her cool with ice in the tank, and she seems to be water tight!
There will be a switch to activate the pump since it won't need to be on for regular cruising around town. I want to control the pump from the driver seat to get maximum cooling right before a run no matter how long it takes to stage.
#90
Everything from the patina 4 door chassis to the vintage cooler was picked out carefully while trying to make it look thrown together to maximize the sleeper effect.
#93
Cooler mounted and secured in the trunk. It came out exactly as I had envisioned.
Wiring for the pump run through the original drain hole.
Better picture of the Jacuzzi bulkheads on the backside of the cooler.
Gold Box has arrived and the harness looks really nice. Plan is to get her tuned on 93 octane once the Gold Box is wired up and sort out the suspension (90/10 front shocks, Calvert mono leafs and cal trac bars on the way). Once she is dialed in on pump 93, the fuel system will be upgraded for e85 and she'll go flex fuel. If everything goes smoothly, she might even run in true street at the Memphis Super Chevy Show in April.
#94
Oil pressure, boost gauge and shift light discretely mounted in glove box.
Wiped the big white M/T logo off the 235 drag radials.
Even got a chance to take her for a test drive in light rain at lunchtime.
Parked at the burrito shop.
Almost scraped my front spoiler lol.
Turbo spools no problem on the trans brake. Boost activated cutout also opens wide at 4psi.
#96
They weren't terrible in the rain but I'm not suggesting they are good for wet driving. Sweet Pea has a 4.8, 2.70 rear gear and a spool so she is a turd from a stop and different than most set ups right now. I tested out the transbrake and the tires spun instantly with a 4.5psi boost launch.
#98
Gold box harness laid out on engine bay to get a feel for routing.
#99
I have collected quite a few parts for my project, but still lack the turbo, cam, valvetrain, 4 of the injectors, engine management/wiring, and other random parts. Ive still got to assemble the engine, rebuild the TH400, and the 8.8 that I have. Been slacking on it majorly not to mention another project I had in the way of it that I finally finished.
