6.0/7875/TR6060 '06 BMW 325i E90 Build
#43
Getting more of the stock electronics to work. Megasquirt can control the stock cooling fan speed controller with a PWM output. Setup a test to increase the fan speed vs TPS.
#49
I drew up the gauge panel in cad by just measuring the panel where I wanted it to fit. I print the profile of the model on paper at a scale to double-check the dimensions and fit. Takes a little practice but once you do a couple it's not too bad.
#51
Got the car moving under its own power, enough to get a little bit of turbo noise out of it. I had to pull it back apart to fix the turbo drain that was poorly placed and causing some smoke.
While it is apart I started putting the ac compressor into the car. I ended up using the BMW compressor to simplify plumbing and wiring. I needed to run the compressor off the front belt for clearance behind it for the hotside.
#52
New updates. Getting the AC lines taken car of. Built a few aluminum barbs to weld on the existing lines so I could crimp on rubber hose. The AC compressor was right in the way of one of the cold side pipes so I had to redo that. Relocated the turbo oil drain the the front cover. Also picked up some new wheels and tire, car fit a 275/35/18 on the back with out any issue.
The following users liked this post:
Homer_Simpson (07-07-2022)
