Procharger belt alignment?
Old 04-21-2016, 12:08 PM
mechamta98's Avatar
Default Procharger belt alignment?
I have the sdce J bracket on my TA, the procharger belt is squeaking. The belt visually looks lined up but im guessing it's not causing the squeak. What's the best way to figure out what way I need to move the bracket.
Old 04-21-2016, 01:10 PM
conan's Avatar
I also had to do a little shimming with my SDCE bracket. I bought one one of these...
http://www.jegs.com/i/Gates/465/9100...FQuPaQodtwQHXA
Ended up getting a .050" thick shim for the blower head unit pulley and had to add a .125 thick shim to the bottom standoff nut to make the J bracket straight to the engine.
Old 04-22-2016, 12:00 PM
mechamta98's Avatar
Thanks I will have to look into getting one of those
Old 04-22-2016, 01:34 PM
tvanlant's Avatar
You will absolutely need the laser alignment tool. There is no way you will ever be able to line pulleys up by sight. Even with a straight edge, you will still have to account for the difference in thickness of the pulley shoulders.
Also, your pulleys could not be paralell to each other. This can be diagnosed by putting the laser on the blower and shooting to the crank. Then put the laser on the crank and shoot to the blower. If they don't match, you've got a parallelism issue.
Old 04-22-2016, 02:07 PM
conan's Avatar
One more thing to add... When you pull the belt off spin the pulley on the SDCE spring tensioner by hand to see it the bearing is going, and spin the original procharger supplied pulley by hand. The squeaking could be a bearing. I would still get the laser tool just to make sure the belt is perfect. Like "tvanlant" said it's a must in my book too.
Old 04-22-2016, 03:05 PM
mechamta98's Avatar
I already checked the bearings. They did not feel bad, but i might just put new ones on.
Old 04-28-2016, 08:12 PM
Yasei's Avatar
Get the Gates laser alignment tool and check the alignment both ways with it like tvanlant said. That's the only way to make sure.
Old 04-28-2016, 08:26 PM
mechamta98's Avatar
Got a new gates tool off ebay today for $31 shipped.
I hope by next weekend I can try and get it figured out
Old 04-28-2016, 11:54 PM
Yasei's Avatar
That's a steal for a new one, sounds too good to be true...
Old 04-28-2016, 11:59 PM
mechamta98's Avatar
Said he won it in a contest and no use for it. I was the only one who bid on it. I have pretty good luck with ebay so far.
Old 04-29-2016, 01:03 AM
8 Second Truck Club
Blown06's Avatar
Damn I paid like 100 bux for mine
Old 04-29-2016, 07:44 AM
conan's Avatar
You and me both... Good find for $31.
Quick Reply: Procharger belt alignment?
