Tool steel pins needed?
I am in process of building a forged 6.0, using wiseco pistons, k1 rods, and stock crank. What HP level should the standard wiseco wrist pins be used? I plan to make over 1000rwhp through the poweglide using the s480 with race cover. Trying to decide if I need the tool steel pins.....
I only make 600 and I did use them I use the wiseco pistons and eagle h beams my builder said there is no point in not using them because it's only a matter of time till u want more boost or faster car why do it twice I'm glad I did too because it wasn't a month and I caught myself turning up the boost little at a time
If the RPM will stay under 8k-run them.
