1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak
Old 11-20-2016, 07:19 PM
  #101
Moderator
denmah's Avatar
Old 11-20-2016, 09:04 PM
  #102
Tomhames's Avatar
Amazing man.
Old 11-21-2016, 12:09 PM
  #103
helicoil's Avatar
Nice, what exhaust manifolds are on this again?
Old 11-21-2016, 02:30 PM
  #104
Moderator
denmah's Avatar
stock 03 z06 manifolds for center exit
Old 11-21-2016, 02:50 PM
  #105
7 Second Club
Rich Halsey's Avatar
That thing is a beast!
Old 11-21-2016, 07:06 PM
  #106
B18B1LS1's Avatar
Still a lot left in the 60', those ET's are going to drop a ton when you guys start to get after it off the line! Awesome build
Old 01-13-2017, 12:05 PM
  #107
Moderator
denmah's Avatar
1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak-69mrtzt.png
1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak-0xbd97w.jpg
Old 01-13-2017, 12:07 PM
  #108
Moderator
denmah's Avatar
dropped an intake valve, luckily it went as well as it could have, mark is getting heads done up and ordered a billet crank and rods, we are gunna shot to max out these turbos hopefully 1600whp for lights out feb
Old 01-13-2017, 12:39 PM
  #109
a05c's Avatar
What class are you trying to fit into? Pro 275?
Old 01-13-2017, 02:17 PM
  #110
svslow's Avatar
Or maybe the leaf spring class.
Old 01-13-2017, 09:07 PM
  #111
Moderator
denmah's Avatar
i have no idea, probably whatever class he can get the most passes in, mark just likes having fun, no way we can compete with big boys
Old 01-13-2017, 09:31 PM
  #112
3pedals's Avatar
Thats awesome
Old 01-13-2017, 09:36 PM
  #113
tblentrprz's Avatar
Matt, what heads were on it? Any idea what valves were in it? I hear more and more about buying bare heads to build with quality parts and machine work that are up to the task.
Old 01-14-2017, 09:18 AM
  #114
truckdoug's Avatar
there's a video on it. afr heads
Old 01-14-2017, 03:13 PM
  #115
7 Second Club
ls3fox's Avatar
it had trickflow heads
Old 01-14-2017, 05:40 PM
  #116
truckdoug's Avatar
herpa derpa
Old 01-14-2017, 10:50 PM
  #117
C/10's Avatar
One bad *** camaro, can't wait till it's back togather, in for some new RWHP numbers..
Old 01-15-2017, 02:19 PM
  #118
M_Minnick's Avatar
They were Manley valves and the heads were assembled by TMS.
Old 04-25-2017, 01:31 PM
  #119
1BADLS1tuner's Avatar
What mix of fuel did you run, I know you used Sunoco Maximal 116.... but was it blended?
Trying to decided if i will be fine running straight 110 with a gallon or two 91octane mix.... or if i should step it up to 116.
AND DAMN i hope my heads stay together! **** luck for sure! How is the reassembly coming?
Old 08-07-2017, 12:21 PM
  #120
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
116 with that combo at that weight and power level makes a lot of sense, would doubt he blended it.
Great results with this combo. What gear out back 3.70?
Quick Reply: 1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak
