Budget Turbo For 700 rwhp
#81
I still got to talk to him about doing mine, but I'm not going to be in a hurry, so sometime this winter it will happen. I've got my truck for sale right now to help fund the build. I think once I sell my current heads, cam, headers, dual exhaust setup, current injectors, I'll have quite a bit of money to put toward the build.
#87
Truck manifolds or a hotside setup from Huron Speed with the manifolds work great and will support far beyond what your planning to do with the setup.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
#89
I believe that's the most cost effective solution. Plus there has been guys making well beyond 1400HP with the factory truck manifolds. Think back to the Ohio Boys and how much power they were making on truck manifolds. It all depends on budget and end goals really.
__________________
#94
sub'd
Seems like we have the same mind set on goals. I'm looking at the same turbo (on3 7875) and would like the same HP goals.
I believe the truck manifolds are a good header to use, and like mentioned above, pair that with the huron speed hot side kit. I wish I was capable of fabricating my own turbo system so for now I'll have to buy a hot side kit lol.
#96
i understand its frowned upon but i tapped the pan with it on the motor.... used heavy duty grease on a drill veeerrrrryyy slowly, as in, 1.5-2 revolutions, take it off degrease and remove shavings from bit, regrease and do it again about 30 times over, then changed the oil 3 times lol never had an issue the whole time i was boosted
#97
Also if you want to save a little time and headache, there are already prefabbed hot sides made for truck manifolds. Before I bought my Huron kit I was talking with a company that had the crossover and downpipe I think for like $475. They have been talked about here on tech before but not very well known.
Edit* The company is RaceFab. Seem to make nice looking parts but I like my Huron stuff better if we are comparing looks.
#99
I don't use a standard drill bit though if it is still mounted. I use a 3/4" hole-saw packed with grease. You aren't punching a whole & making it bigger as bits get removed.
Then pack the tap with grease as well & thread it in a few turns then clean & repack. Lather, rinse, repeat. Given the variances of NPT tolerances test the fitting as you tap it so you don't go too big tapping the hole & end up with a loose fit.
#100
Well, apparently ON3 has a new turbo that's now in the mix. It's a 84mm turbo, T4, 755 exhaust wheel, .96ar 3" v-band outlet. $625.00 is the price, but that's not with the ceramic ball bearing unit ($199.00 more), or with the billet wheel upgrade.
