69 Camaro SS (9 second club) Sloppy mechanics track day
Best part of this all is I had a bare block a week ago and built the motor myself for the first time ever. New main bearings reused rod bearings. Worked 10 hour days and would come home spend time with my kids til they went to bed and work on car from 9-til 2-3am. All paid off on fri. Very supporting wife helps a lot too. Couldn't be much happier with results.
Yes my gen3 combo made with 10.5 afr 656whp at 6100 rpm at 18psi. Stock 862 heads and dished 5.3 pistons. When I swapped gen 4 stuff in last week I put stock 799 heads on. So it's basically an iron blocked l33 with a ljms stage 3 turbo cam. im guessing my old gen 3 setup was 700whp at 20 psi. I'm hoping for mid to high 700's with flattops and 799 heads with correct 11.0-11.5 afr. I'll dyno it in spring to see. Et/mph/weight calculator say 800's but I don't go by that I go by actual dyno numbers in my hand. Lol
