Wiring the CS130 style alternator.....?
Old 12-08-2016, 09:40 PM
red fury's Avatar
Default Wiring the CS130 style alternator.....?
I am using the Speed Inc. alternator relocation bracket. Relocates the alternator to the top side on the passengers side. Speed Inc recommends CS130 style alternator....
Off the factory harness going to the factory alternator there was / is a single red wire that is connected to the plug that plugs into the alternator. Will that single wire when connected to terminal I on the CS130 alternator trigger it to charge?
I am trying to figure this out tonight....
Old 12-09-2016, 07:41 AM
svslow's Avatar
This is how I had mine wired, minus the ground going to the battery. I just had a switched 12V going to the 'L' terminal and the 'S' was tied into the post going to the battery. I had terrible luck with that bracket set up, couldn't keep a belt on to save my life.
Old 12-09-2016, 08:21 AM
red fury's Avatar
Thank you!!!!
Old 12-09-2016, 05:10 PM
red fury's Avatar
Worked like a charm!!! Thanks again
Quick Reply: Wiring the CS130 style alternator.....?
