Just a simple where would u put my wastegates
Like it says I have circled where I think I want my wastegates but I would.like to have them out of the way because I'm not 100 percent surethane where the last of the ac pieces will go once my wife's car is done it's a 6.0 twin s366s in a 2000 Mustang it's a street car she agreed to new ***** I agreed to build her the car she wanted no questions asked and here we are
Thanks I built mine and she likes it but being in an s10 its just not the same I guess so she got a man's motor in a chick car and I'm ok with that plus I enjoy the build she has done more than her fair share she did all.the soldering the wire loom.work and she did the radio and all the trim re install on the insides I am trying to keep the air conditioner I believe I can butell I don't know what I need as far as hoses and all that my ride doesn't have air just heat
Dam...you sir have it made. ha ha
As far as wastegates I would place them off at an angle in the direction of flow at those locations..or at a bend, put them off the outside radius. the flow will favor the outside radius when it has to turn and you can control boost great when they are placed in this location. The only thing I found is you get exhaust flow driving stright into the gate valve when placed straight off the end of the bend. the result was not being able to get really high boost pressure until I put pressure to the dome of the wastegate. Before that though, a 10psi spring only allowed me to hit about 17psi before the gate opened itself with no line going to the gate. The plus side is if the line ever falls off, you have built in boost cut off ha ha
Porting Snail Housings
Hi, forty years I had the same question with my Pantera TT kit.
The customers wanted trunk space so I placed the Waste Gates onto the Snail.
That placement was at the END of the Scroll, the closest small area at the Exducer Tip.
What was found :
That higher gas speed mounting area allow for a smaller valve AND reduced E-MAP.
The power increase was great when compared to you chosen location.
I would be able to provide more information.
I used one of Bob Kellers waste gate kits (unassembled) and made my own steel base.
I have stock to this day.
Lance
What was found :
Lance
Not sure how much room.ill have to try that with the bumper tucks really close to everything. I maybe could ger away with one side but the charge pipe would probably block the other side. Inteecooler goes right in the middle
